Southern Misfits Atv Riders
Welcome to Southern Misfits Atv Riders
    Broken Bolt Removal
    Share
    The Big Show
    The Big Show
    Admin
    Broken Bolt Removal
    Post by The Big Show on Sun Jan 09, 2011 9:28 am
    While installing my new UHMW skid plate on the Rzr I had a bolt head to break off on the
    bolt in the concave washer. I didn't have a easy out kit to remove the broken bolt, so
    here's what I used. First use a drill with a bit smaller than the broken bolt to drill a
    small hole in the broken bolt. Then use a torx bit small enough to be tapped into the hole
    you drilled with a hammer. Then use a ratchet and socket to back the broken bolt out.
    _________________
    2010 Rzr S Orange Madness
    Southern Misfits Atv Riders Member
    East Tn Atv Riders Member
    ky kodiak
    ky kodiak
    Re: Broken Bolt Removal
    Post by ky kodiak on Sun Jan 09, 2011 4:05 pm
    you DA man!!! cheers
      Current date/time is Thu Mar 21, 2019 2:46 pm
